Turning Off Gas Supply To Fireplace
15 Jul 2008
We are wanting to rip out our existing gas fireplace and plasterboard the recess. Do we need a gas-safe engineer or is it sufficient for us to turn the supply off at the tap next to the hearth?
If the latter, then do we turn the screw anti-clockwise and remove the 10mm supply pipe? Will this be safe?
The pipe should be capped off, by a gas Safe person. I'd suggest below the floor if you are removing the fire permanently.
+1 you can not legally do this yourself but not a big job so shouldnt be expensive
