Turning Off the water to remove radiator
5 Oct 2006
I'm removing two radiators, I know I dont have to turn the water off, but after my last effort removing a radiator I think I should :? Therefore if Im removing a radiator where do I need to turn the water off is it loft or would it be downstairs some where ?
Also if I did have a problem when removing the radiator and did have the water turned off, would the water still come out of the radiator feed pipes until the system was empty ?
No need to turn the water off. Just issolate the two rads in question using the lockshield/TRV valves, then drain rads off into a small bowl.
Note how many turns to close the valves, and when replacing the rads open the valves with corresponding number of turns.
Sorry off too the range now to practice for tomorrow :wink:
