What's the general opinion of this RG6 cable product offering?
Its states
- 1mm solid copper coated steel conductor
- 64 x .12mm aluminium braid
- Foam dielectric
- Aluminium foil shielding
- PVC Sheath
- Overall diameter 6.4mm
- Nominal attenuation @ 1MHz = 2.82dB
- 75 Ohm
To break down why this is bad:
- 1mm solid copper coated steel conductor and Nominal attenuation @ 1MHz = 2.82dB
What's more concerning is the attenuation. This is signal loss, and it is normally given at a frequency, and the dB level, and importantly the length which is often per 100m. This one doesn't do that, but we'll give them the benefit of the doubt that it's not per 10m.
1MHz isn't a frequency that terrestrial TV uses. It's not even baseband video (5MHz - yellow RCA, composite video). That's alarm bells immediately. You see, signal loss increases with frequency. Too much , and the effect is to reduce the length of cable you can use before the signal becomes too weak.
WF100 is less than 1.6dB for 100m measured at 5MHz. Given that 5MHz is a higher frequency, and that 2.8dB is almost twice the loss at a lower frequency, I think it's safe to presume the eBay stuff is twice as lossy across the board. That's bad.
- 64 x .12mm aluminium braid and Aluminium foil shielding
- PVC Sheath
- Foam dielectric
- 75 Ohm
Your eBay cable is £14 for 50m, so the equivalent of £28/100m. This TX100 is £45/100m. It's 28p per metre and a whole load of trouble down the line, or 45p a metre for peace of mind.
