A few months back I installed a digital aerial on the roof which was connected to a freeview box on the ground floor. Reception was perfect as the aerial has good line of sight from the roof.
I needed a second connection to an analogue TV in the bedroom so ran another cable to it from the aerial and temporarily connected it to the same screw connections on the aerial. Again reception was perfect for both the analogue and digital TV - all channels.
Recently I needed a third connection so decided to do it properly and fit a masthead splitter with a variable gain amplifier (which can be connected to one of the downleads in the house).
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=26562&ts=40380
I went this route as i didn't know what strength the signal was and I would be able to vary the gain if necessary.
Now that three cables are connected, the reception is poor on all connections, varying the gain on the amp doesn't help. The analogue signal is grainy and the digital set isn't picking up half the channels it used to.
Am I not getting enough gain ? How can I rectify this?
