The deepest metal boxes I can find are 47mm which is the cooker box and the floor screed thickness will be 75mm therefore 28mm difference. Do you screws/plugs the metal boxes to the concrete base then use longer socket screws or pack the boxes up to the correct level to the floor screed finish then may have a problem with conduit trunking being tilted near the sockets?
