and you've already retained the services of a sparky who is willing to let you design and install this and will sign it off fraudulently to say he's done it?
got his number?
hmmm, not seen them before, the frame are being made up now and I don't know if there's room to hide the T&E cable yet unless the neutrik socket have a backing box without having to drill it into the frame?
fair enough.. the pic hadn't shown up when I started to reply and a quick google it looked like a inner and outer type affair, I didn't realise there was an earth..
553.1.4 Ah. From memory I thought shuttering was a "preferable" not a "shall be".....
Trunking in a brand new conservatory would look tat.
I would not use cable tray, I would fix conduit directly to the oversite, given a day or two it would be fine for fixings. (5.5 drill and red plugs).
You could always put in a continuous piece of conduit, more than likely 25mm, with a 90 bend each end to bring the conduit up out of the screed. One end for the light, the other end by a wall socket.
got his number?
I'm sure it will be okay if I do everything correctly and take a photo of the layout, if the electrician is not happy then I shall let them do it their way
Will do, thinking it about it the heat in the conservatory should dry it out quicker
you want female ( no thread intruding into the box.. )
and those particular bends do just plug onto the pipe ( but the adaptor wouldn't fit the bend so a piece of pipe is required between bend and adaptor )
don't use bends, get a bending spring.. no joints to get the cable stuck on that way.. or at least fewer joints
