Just out of curiosity, with these new "17th edition" consumer units, I wondered how the two RCDs would be used. I considered having two went I was planning my layout a few year ago.
I just don't see how you could make things that much more convenient. Okay you could have lights and shower on one, and then the hoover blowing up doesn't spoil your shower, but the shower shorting out leaves you in the dark.
Are there some statistics to show which are the most likely circuits to have faults?
I'm now about to have some work done on my CU, and adding another RCD is probably compulsory, the instantaneous load could reach 90A and the main fuse and isolator are both 100A but the RCD is only 80A. In this case I'll ask for the shower and elec boiler which are configured to operate only one at a time to be on one RCD and the rest on the other - unless there are some words of wisdom from here (or the sparkly).
