Literally can’t find anything which related to two bells and the texecom premier I’m obviously being thick. Can you point or kick me in the right direction?
Connect the 12v, bell trigger and strobe trigger of both boxes to the 12v, bell trigger and strobe trigger connections on the control panel. Connect the 0v connection of the panel to the 0v connection on the first bell, connect a link wire from 0v to one of the T terminals in the first bell. Connect the other T terminal to the 0v terminal on the second bell, connect a link wire from 0v to one of the T terminals in the second bell. Connect the other T terminal to the tamper return terminal of the control panel.
Don't forget to enable the batteries in both sounders (move battery link to "internal" pins) and enable SCB mode on the second sounder.
