if two transformers coil outputs are connected in a series circuit, am I right in thinking their respective output voltages will behave in the same manner as two 12V batteries connected in series on an HGV in that both bells will be operating at the combined voltage of two transformer coil outputs ?
Provided you connect the transformers 'the right way around' (so that their voltages add, rather than subtract), if the bells are also in series, then the voltage across the
two bells will be equal to the combined voltages of the two transformer outputs. However, if the bells are identical, that voltage will share equally between the two bells - so each bell will be operating at the voltage of
one of the transformer outputs. ... just as if you had two 12V batteries in series in your HGV and connected two identical bulbs in series across the combined batteries - there would be 24V across the pair of bulbs, but 12V across each of the individual bulbs.
Kind Regards, John
