Two loos in a line
10 Jul 2007
Lancashire
Hi I am trying to fit an extra toilet in an en suite whilst doing the bathroom as well! The problem I seem to have, is the soil pipe is internal and the existing loo just has a 90 deg bend into it, I am thinking of putting a 110mm pipe from the soil with a Tee to the first loo and then on to another loo with a 90 deg bend. Is this ok or will I have problems when the furthest loo is flushed going back up the the other one? If not ok does anyone have any ideas?
Should be ok as long as you fit the swept branch the correct way round.
Thanks for the answer. Have you seen a similar system actually being used? I don't want to fit them and find I have a problem. I have been told elsewhere that it is not normally done and in places that have lots of loos like shops that they have something like a non return valve. Have you come across anything like this?
