Two radiators downstairs not working
31 Dec 2010
Northamptonshire
We have just moved into a new house and two rads downstairs really struggle to get hot. We have had a plumber round who replaced the pump balanced the rads and it still doesn't work properly. Anyone have any ideas as to why this is happening?
Turn the hot rads off and see if the other two get hot, if they do then it's a matter of re-balancing the system. Or they could be full of sludge. Remove rads and flush with hose pipe in the garden.
Beware of white carpets. :D
Andy
Thanks for reply. We have had the rads rebalanced and they were cleaned not to long ago do you think then would need cleaning again?
Depends on what sort of 'clean' you had done. Powerflush done properly should have cleaned all the muck out. If you paid the guy to sort out the 2 rads that weren't working, he's not actually managed to achieve anything, get him back!
Have you tried turning all the others off as per Andys suggestion?
Hi
I have managed to get all rads working the two that were not on before are now warm but not as hot as others is this the best that I will get?
Thanks for your help
Should be able to get them all at about the same temp. Sounds like you still have an underlying problem somewhere, i'm doubtful about that 'clean' you had done.
Hi
how did you do this?
