two seperate "funny" noises........
http://www.fernox.com/?cccpage=break_down_guide&sub=2
if you can drain the system refill it. you can run it for a while then re drain it gets most of the loose stuff out.
can you get a hose to the loft or you can make a temp hose off the ball valve mains feed.
great, thanks for the link, all links bookmarked, thanks.
yeah i'm sure i can get a hose in the loft !, ta.
tim
makes it a bit quicker and bit better pressure if you can aim it in the feed pipe to the system give the air seperator a flush through.
then give it a refill and let the chemical do the rest.
Air seps don`t you just love them meant to be the be all ,but its amazing how many of them block nearly solid with just about a pencil thickness left for the water to flow
Giving symptons of several rads not working but others red hot. First few times you got caught by thinking its got a seperator so noway will it be blocked. Wrong
Yet others stay clean as a whistle for a lifetime
