Two showers on power pump
30 Jul 2008
Staffordshire
We have a single power pump feeding two showers.
when one of the showers is on, the other shower leaks a fair bit (water comes fro shower head). The main consequence is a lack of flow to the Shower being used.
The ‘leaking’ shower is a Grohe bar control - not sure what model but about 7 years old.
Can the flow valve (excuse imprecise terminology) in the control be adjusted/tightened up, do I replace the flow valve in the control, replace the entire control bar or is there some sort of control valve that can be inserted in the pipe work?
If it's a bar shower with a 1/4 turn on and off valve at one end then no, the ceramic valve needs replaced, Grohe will be able to provide replacements. if it's a centre exposed valve then the whole valve assembly may need replaced, a pic may help, again though, Grohe will normally have replacements.
Why don't they both leak when off as the pressure will be even higher?.
Oh yes, Pump is off!!.
See image below.
