    Dismiss Notice
TXL silver insulation
Discussion in 'Building' started by Jh72f, 13 Jun 2018.
  1. Jh72f
    13 Jun 2018
    Thanks Received:
    Country:
    Having a loft conversion and TXL silver has been used without another secondary insulation, should we be concerned?
  2. noseall
    2 Feb 2006
    29,696
    Thanks Received:
    1,889
    Staffordshire
    Country:
    Probably.
    • Like Like x 1
  3. freddiemercurystwin
    21 Jan 2007
    18,057
    Thanks Received:
    1,965
    Devon
    Country:
    Yep, it's a pointless form of insulation, it has to be installed with an air gap above and below and in addition to 90mm of celotex or whatever. There are no advantages to the consumer.
  4. tony1851
    23 Feb 2012
    8,275
    Thanks Received:
    1,195
    Manchester
    Country:
  5. John D v2.0
    26 Aug 2016
    4,648
    Thanks Received:
    614
    Country:
    yes, the thermal resistance of a reflective surface facing into a void is not really close to the minimum building regs requrement. Furthermore, it is very easy for air movement / thermal bypass to make that kind of insulation next to useless, and hard to stop the air movement..
    In theory it could work well, but in practice it would be like a single glazed window.
Loading...
Share This Page
