UFH pipes - unions.
23 Dec 2012
Suffolk
Hello,
I've had wet UFH installed in a recent extension, and I've asked the plumber to install a manifold with spare ports for future expansion, which he's duly done. The intention is that I'll (or get a firm in to do it) gun up the tiles and concrete floor in the rest of the house and lay UFH to the entire ground floor. The UFH manifold is mounted on a wall the other side of the heat source (a gas fired Rayburn) which itself is also due to be moved (330kg worth!!). I'm considering a number of strageies to get this work done..
a) Do the whole lot in one go, including moving the Rayburn
b) Move the Rayburn, then do half the house at once
c) Move the Rayburn, and do a room at a time.
options b and c made somewhat easier by using the under-the-stairs cupboard to route all the pipes to initially then use unions - above the floor level, to later connect to at a later date.
My question... Given it's bad form to use connections on UFH, are they even available to buy? I see push fit connectors for plastic plumbing, but I think that's for a different type/diameter of pipe.
The rest of the background is to get a bit of feedback if it's worth doing it piece-meal.
Nozzle
You should never make joints below floor level on UFH.
Perhaps push fit are available but I have never seen them.
The compression ones are very expensive and fit the odd sizes used for UFH.
I don't see any good reason why not to use standard plastic barrier pipe for UFH being its cheaper.
Tony
