hi I've a property with two ultracom boilers, which used to heat up fine, this year not as well, when I look at the boilers I notice that one of the boilers is showing a steady 75 deg which is what its set at, but the other isn't reaching its temp which is supposed to be the same, it does try every ten minutes or so and then goes out, it comes on say at about 60 or so and climbs up to the 75 deg mark with all five lcd burner indicators on, I assume at max ? but when it reaches 75 instead of dropping down to around two and holding at 75 , like the other one does, it seems to keep going and then goes out and it all starts over again, my plumber says he's checked the stats and the pumps and there ok he also tells me he has range rated it to 7 kw? and it still does it, not sure what that means but he says that means its not the pumps
any ideas
any ideas
