- Joined
- 11 Jan 2009
- Messages
- 1,101
- Reaction score
- 6
- Country
Yes indeed. Was about 10 years ago, so probably thinks it’s had a good innings.
Looks like the Dudley Vantage button to me, it could be the bellow has failed in which case you can try a new flush button but they are not cheap at £25.Thanks for helpful replies. Cant seem to upload at moment, but can confirm air rather than cable operated push button. Have already tried removing and blowing tube but no joy. Original fitter (unable to do job) recommends removing silicone, then section of worktop, and sink. Doesn’t think any need to break or remove tiles.
Can not see from your pic, does worktop run between 2 walls or is left hand end open? When you do get access to it I would suggest complete new internals, fill & flush valve. Also replace braided flexi while you are at it. Fingers crossed that you get another 10 years out of it then.
So the edges are tiled in & top will not slide forwards or upwards presumably without removing some tiles
I'll send a link to the button when home around 9.
Cutting 5mm off the hoses can work
