Unable to locate thermostat reset on 25/32 greenstar
6 Sep 2014
Hi
We have a greenstar heatslave 25/32 model boiler. Locked out this morning. We have looked at the instruction booklet and can't find the thermostat reset or heating reset button which are supposed to be behind the front panel. The lockout reset button has been located as in the diagram but the others are nowhere to be found - any ideas??? .....
Thanks for any help
Under the front edge of the control panel ?
Have a look at the diagrams on page 6 & 20 in the manual
Many thanks for your message and help.
I've looked as per the instruction booklet under the front edge but there isn't anything there.
At the bottom left there is a unit covered in foil. On the front is a sticker saying reset buttons and then two arrows pointing to two circles. Underneath One it says "flue", the other "boiler". I've pushed the circle assuming the foil is underneath (???) but the boiler is still not firing up on demand.
If it's locked out then there must be a reason - time for an engineer methinks!
