Unable to register a DO800M
26 Mar 2011
Aberdeen
Hey all, I've just purchased two DO800M wireless door contacts... From eBay, both as new.
One paired to my G2-12 (v1.50) with C079-2 fine... 52 > Zone> 5, force tamper...
The other, just doesn't seem to be registering the force tamper. Afaik, there's no way to locate the serial number to manually enter it.
Pushing the tamper button by hand triggers the LED. I can hear the tamper been triggered when sealing the DO800, and again the LED flashes. I've tried getting the tamper to trigger with the DO800m in situ, bang next to the C079 and also with the 'contact' open and closed. With no joy...
Defective unit??
Which firmware version is the C079-2 ? Label normally on the PCB.
Also, have you tried power cycling the C079-2. I've had a situation previously where the module wouldn't detect a remote, but was seeing the sensors. A power cycle of the module corrected the issue.
I assumed as one regged that all would be ok. I will try a power cycle and have a look to see if I can see a fw version of the c079.
Thanks for your reply!
advice;
remove battery from door contact, short the battery pins, on the contact, re install battery, try again.
also with the PIR sensors, the new range, do not register them at the RF module, as they are now fitted with a back tamper.
Oasis
the above info was given to one of our engineers last week as he couldnt register two devices!! he didnt phone the office, he called Honeywell tech first!!
Thanks, it gives me something else to try!
I don't have any RF PIR's just DO800M door contacts... I will try your suggestions tonight, thank you.
Open to more advice though should that not work!
Shorting hasn't helped :(
Knowingly... All power in the house has been off today, would that power cycle the C079 or would the G2 battery have kept that alive?
The alarm was in a CU AC fail...
Unlikely. If the panel has RF sensors and a 7A battery, then it would keep running.
I've added an IR800M today, in the place I wanted the DO800M, without any issues. This DO800M must be faulty surely...?
Perhaps, but as I said, I had a portal that was working fine with one device and not seeing the other at all until power cycled.
Power cycling the Galaxy panels does not lose the settings, only the time and date.
I tinkered with the Frequency POT on the actual DO800M and finally got it to register! Typically, by adding the IR800M I don't actually have use for this DO800M anymore!
Thanks for all your help.
