(I'm no expert but will do a lot of research and attempt most things if it will save me money and is legal to do myself)
I moved into this house 1 year ago, but I think the boiler (Worcester 532i) is about 8-9 years old.
At the weekend I moved a radiator (Someone had mounted it very high on the wall and I cut down the pipes and moved it down so I could fit a Dado rail at 3 feet)
I didn’t see any sludge when I was draining the system but a small amount did leak out of the radiator when I moved it (this radiator looks older than all the others on the system). (really wish now I had flushed out the radiator!)
I don’t know if there was inhibitor in the system but the water did smell quite chemically and was clear, so I'm thinking there was.
I re-pressurised the heating system and bled the radiators of all air and ran the heating and all the radiators got hot quickly and no Leaks from the one I moved J
The problems was noticed when I was trying to run a bath, The water got hot but after about 15 seconds went cold again.
We have had this problem intermittently since moving in but used to happened sometimes after about 5 mins running the bath tap, so has got a lot worse!
I took a look at the boiler with the tap running and the temp gauge just keeps climbing to 109 and then I hear some value click and the flame goes out and the temp slowly starts to fall and the water goes cold. I cannot see any water coming out of the overflow pipe outside.
From doing some googling I think that sludge from moving the radiator has blocked up the heat exchanger (but which one?)
I have ordered some sentinel x800 to see if this clears it out of the heat exchanger.
I guess my questions to the forum are:
Do they think it is the heat exchanger or something else?
Is there a chance the Sentinel x800 will clean the heat exchanger? I have seen on forums others having some success with this. I know because I have an aluminium heat Exchanger I should limit the time of the x800 in the system to 3 hours (But if the exchanger if buggered anyway, might as well try)
For £55 should I fit a Magnaclean first? So that sludge loosened by the Sentinel x800 is captured in it before getting to the Boiler?
I don’t want to pay £500 for a pressure flush of the system (I wish I earned £100 an hour!), but is it worth taking off each radiator in turn and running a hose or pressure washer through them?
If that doesn’t work will I need a:
(I would get a local engineer to fit these parts if I need them)
£50 odd quid Plate heat exchanger?
Or a £400 odd quid main heat exchanger?
Any ideas would be great.
I'm on a tight budget as we have a baby due in a few weeks ,
So will be trying to do must stuff myself to avoid the high labour costs.
