Unclogging 6mm Marcrist diamond drill bit
16 Jun 2006
London
Hi all
I have a Marcrist G750X for drilling holes in porcelain tiles.
Unfortunately, one of the hole cores is stuck in the middle of the bit which means that drilling has become really slow and applies an unhealthy amount of pressure.
How do you remove it?
Does the hole go right through the bit, if so just drift out from the other end with a rod/screwdriver. Cores can often be dislodged by tapping the side of the bit on a hard surface like a vice.
