    Dismiss Notice
Under cabinet lighting. Supply from cooker hood?
Discussion in 'Electrics UK' started by houstonwehaveaproblem, 20 Nov 2018.
  1. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Hi all.
    In the process of installing an angled cooker hood above our hob.
    At the moment we dont have any wall units either side of the cooker hood but now think it looks a bit bare so i am going to fit some either side.
    I would like to have some under cupboard Led lighting but as the kitchen has been plastered and painted the only way i can see of doing this would be to spur off the cooker hood supply cable. Is this ok?
    There is a FCU adjacent to the cooker hood chimney at the top of the wall/ceiling. This is the supply for the hood.
    I was looking at putting a junction box inside the chimney and running cables to eachwall cupboard but this would mean notching out each side of the chimney at the bottom for cable access. The cable wouldnt be on show.
    Does this sound ridiculous??
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    63,799
    Thanks Received:
    3,373
    Gosport
    Country:
    Cook Islands
    If you run the cable above the wall cabs and hoods it will be out of sight and you don't need to chase it into the wall. Mini-trunking will protect it from grease.
    Is the outlet fed from the lighting circuit or a socket circuit?
  4. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,141
    Thanks Received:
    1,925
    Oxfordshire
    Country:
    How will you switch the lights on and off?
  5. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Ring main switched FCU
  6. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Fit a switch under the cupboards ?
  7. Sponsored Links
  8. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Ahhh i have noticed the hood wiring has no earth wire in the cable.
  9. JohnD
    JohnD
    15 Nov 2005
    63,799
    Thanks Received:
    3,373
    Gosport
    Country:
    Cook Islands
    is there an earth wire from the supply inside the FCU?
    photos would help.
  10. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    Yeah the FCU has incoming earth wires and an earth wire from the back box to the FCU
  11. houstonwehaveaproblem
    6 Nov 2008
    625
    Thanks Received:
    10
    Country:
    The under shelf lighting we have on the other side of the kitchen also has no earth. These are wired via a plug
  12. JohnD
    JohnD
    15 Nov 2005
    63,799
    Thanks Received:
    3,373
    Gosport
    Country:
    Cook Islands
    You might consider this:
    take a flex from the FCU to a multiway adaptor (or a junction box or wiring centre if you like that sort of thing)
    supply the cooker hood and the lights by plugging into the socket or connection
    you will have to add cable restraints if not using plugs
    It could go in or on one or your wall cabinets.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
