undercabinet lighting Hardwired
12 Jun 2012
Cheshire
Hi guys behind a corner wall cabinet in my kitchen ive got a 1mm cable coming up directly from the fusebox and is covered with just a blanking plate. How do i wire my under cabinet lights to this? Can i put a switch on there and can i use lights with a transformer? Cheers guys. :D
Providing the cable is in good condition and coming directly from the CU via a RCBO or a MCB that is protected by an RCD. You can either install a switch or a switched fuse connection to the cable. This can then either be connected to lights of low voltage (mains 230v) or to a transformer at extra low voltage.
As it is in the kitchen, certain legal requirements need to be made in regards of notification of work!
http://www.diynot.com/wiki/electrics:part_p
Strictly speaking, additional protection by means of an RCD may not be required depending on the reference method for the cable.
