I am in the final stages of building an extension. I have now decided I would like wet underfloor heating. The problem is the extention is built with the 100mm insulation underneath the slab and not on the top.
I still need to put a 50mm screed down.
Am I able to install wet underfloor heating? How would it fix to the concrete slab (I know it is normally cliped into the insulation)
Could I use the waffle matting to fix the pipes into instead of clipping? The insulation is below the slab and all around it's edges.
Any advice would be great. Jono.
