I have a speedfit underfloor heating system and I think my mixing valve is not working properly. Water from the boiler is hot, but it's luke-warm when going into the heating manifold and no turning of the knob on the mixing valve will change the temp.
I've purchased a new valve and would like to change it myself.
I understand that I need to shut the flow to and from the boiler, but what will happen when I remove the old mixing valve? Is the water in the UFH system under high pressure? If so, do i need to re-pressurize it after replacing the mixing valve?
Apologies for the amateur questions
