I have a wet underfloor heating system installed between joists in a 1930's house. The heating system itself works.
The issue is with the subfloor....
The builder installed insulation between the joists, then clipped the pipes to the insulation as seems to be the standard approach. He then filled the gap from the top of the insulation to the top of the joists with dry screed and installed water resistant chipboard over this to complete the floor. So far normal.
He then had flooring contractor come in to lay Karndean and flooring contractor tacked 4mm ply to chipboard and glued the Karndean onto the ply.
The problems after about 3/4 weeks was some tiles came loose and when they pulled up the loose tiles they discovered water stains , they could not find the reason for the water (undefloor system pressure steady) so they re glued new tiles and all seemed well for a while and now after a year we had the whole floor (Karndean & Ply layer only) pulled up after more tiles came loose, ridges appeared where the ply joins were indicating ply expanding or moving. On removing floor we now see water stains (dry to touch) in various places around the floor on the chipboard.
Questions I need help with please ...
1. Anyone else had this problem? or anyone have any ideas about where the water between chipboard and ply had come from?
a. Is it the chipboard or ply drying out with the underfloor heating driving the process but as it's sealed in by the Karndean nowhere to go?
b. Think heating went on immediately to test it after they laid floor, could it be the high temp adhesive not given time to cure/set?
2. I am wondering if the dry screed is the source, builder says he left it 2 days after putting the mix between the joists before covering with chipboard. Would that be enough time for excess moisture to dissapate before covering it? What would be the normal time before covering dry screedin this manner?
3. Should I tell them to pull up the chipboard to check before recovering with new floor? It will cost but prefer we dry it out if the dry screed is the source of the issue before starting again.
Thanks.
Thanks.
