I'm trying to make use of the space under my stairs by turning it into a cupboard.
I've made a whole in the plasterboard big enough to crawl inside and now I'm in I've found a few things that raise some questions.
The stairs are open on one side and join an internal wall that has the garage on the other side. Obviously this wall is block work, not a stud wall.
My garage floor is several inches lower than the rest of the house, which is pretty normal I think.
My lounge floor is the same height as the rest of the ground floor.
The floor space under my stairs is somewhere in between the two.
The plasterboard wall I've broken through was simply a stud wall.
It had a top and bottom rail and 3 vertical studs.
When I look at the bottom it looks like the DPM for the lounge floor stops there.
What do I do in my new cupboard under the stairs?
I'm not putting anything particularly precious under there, do I need to do anything?
I'm thinking I could simply seal the concrete and paint it with some garage floor paint (that's all I did in the garage).
Alternatively, I could batten the floor, put some loft boards on it and then tack some carpet on top. If I do this, do I need a DPM? It's starting to sound like an expensive project for something that was supposed to be a quick 'knock a door through a plasterboard wall' job!
Thanks,
C.
Thanks,
C.
