unlevel dilema
18 Nov 2005
Got a bit of a strange one here
Re doing a bathroom (my own not a customer's) and I have a bit of a strange issue
Currently battoning ceiling out for new boards and getting everything square and plumb as much as I can for floor to ceiling tiling
I leveled the ceiling and it looked way out (by eye) spot on on spitit. By way out I mean on Windows and above doors
So checked floor for level both ways and that's spot on (original floor)
So then decided to mark out a ceiling line at 2.4m and re do battens everything looks fine this time I even individually checked height of each timber from floor and all 2.4 both ends and in middle
Stuck level on it and it says it's way out.
Now I'm a plastered by trade so do my fair share of stud wall and ceilings and never encountered this
I have checked with two different levels just to rule out a bad level
Anybody know what's going on?
I know the most important thing is for the overall finished room and tiles to looks right and not 100% of the time can it look right and be plumb everywhere but I'd like to know if anyone has any ideas as to what's going on
I've used a different level so can rule that out the door is definately square
Window could well be pi**ed haven't checked that
For now (unless it Bugs me) everything is lined up by eye
I don't mind it being out of true slightly as long as it looks right when it's all done
My biggest concern was having it look off when it's tiled so thy that's the main priority making sure that when it's tiled there isn't a massive difference in the top cut tiles around the room
I've always worked on the " if it looks right it is right" philosophy no matter what the level says and have even put stuff in well out of level or plumb but it still worked and looked good.
As you are tiling it I'd be inclined to set out the tiling to see if the " error" is evident , drawing lines on the wall should help.
