unvented cylinder in a basement
24 Sep 2009
Nottinghamshire
hi i intend to put a santon 210 in a habitible basement for a customer but have the problem of how to terminate the prv pipe as the pipe has to run continuasly down to a drain?
i am bellow ground level by 2 m with no drianage so how do i terminate this and comply with building regs
help!!!!!!!!
regards
chris
You run it into a drain, assuming they have drains for toilets etc.
Provided it has a tun dish it's perfectly acceptable.
It is best to fit a DHW heat bank/thermal store in these situations.
If there is no existing drainage then you dont.
How come you didn't pick this up on the site survey and suggest another location :?
A vented heat bank/thermal store with a detached header tank above ground level will do it. Sorted.
You will find yourself in trouble if no natural drainage as you will find Nobody makes a sump pump that will handle water in excess of 95'c
a friend of mine landed himself in hot-water (no pun) recently when he fitted one of these in a basement on the instruction of a consultant, a long and legnthy litigation followed and my friend copped the rap, sylinder had to be re-located further up the building so DONT DO IT!!!! :wink:
An excellent example of why we should all have Professional Imdemnity insurance :wink:
Hear Hear!! The Judge said that it was the Installer that held G3 certification and therefore should "have known better" :cry:
That is why I said...
"A vented heat bank/thermal store with a detached header tank above ground level will do it. Sorted."
If you are professional and know this business you will not need to claim on indemnity.
