    Dismiss Notice
LPG boiler in basements?
Discussion in 'Plumbing and Central Heating' started by sturharv, 14 Mar 2008.
  1. sturharv
    sturharv
    4 Sep 2007
    219
    Thanks Received:
    Lancashire
    Country:
    Just a general question, I know there are regs on installing LPG boilers in basements, basically it isn’t allowed.
    What about installing an LPG boiler in a plant room where only two of the outside walls on that floor are below ground, but the other side of the building is at ground level??
    There are no outside walls available to the plant room, there would have to be a vertical flue on the boiler.
  2. Sponsored Links
  3. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    What do you mean by no outside walls available
  4. Slugbabydotcom
    Slugbabydotcom
    10 Mar 2005
    3,512
    Thanks Received:
    86
    Middlesbrough
    Country:
    LPG appliances are not allowed in basements because LPG is heavier than air . Any leaking gas could gather at low level with potentially disastrous consequences.
    The big question is:-
    Is there a doorway from that room that leads to the outside at low level [plant room floor level]?
  5. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    I was getting round to that SBDC, if there was a door it would be an lower ground floor.
  6. superdupergasman
    superdupergasman
    4 Jan 2008
    797
    Thanks Received:
    Edinburgh
    Country:
    In your circumstance the answer is no!
    Only if there is one outside wall would it be allowed.
  7. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    :confused: :confused: :confused: :confused: why not two.
  8. superdupergasman
    superdupergasman
    4 Jan 2008
    797
    Thanks Received:
    Edinburgh
    Country:
    should have said one or more! :D
  9. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    He's got 2 but they're not available whatever that means.
  10. Sponsored Links
  11. sturharv
    sturharv
    4 Sep 2007
    219
    Thanks Received:
    Lancashire
    Country:
    Sorry I have been a while to reply.
    Basically there is an existing plant room, however the building is being extended and 'built onto' the plant room walls. Originally there was a door on the plant room to outside.
    Therefore the plant room now has no outside wall available.
    The front elevation on that floor (the floor which has the plant rom) is at ground level i.e. you could walk out of the doors at the front to outside, but the rear elevation is built into the land, you would have to go to the floor above to walk out of the rear of the building. The plant room is on the rear elevation, but there is a doorway from that floor (but not the plant room) that leads to the outside at low level.
    Hope I have explained it correctly.
    :LOL:
  12. Mike2007
    Mike2007
    10 Feb 2007
    1,331
    Thanks Received:
    34
    Cumbria
    Country:
    If your on LPG and not natural gas change over to oil, I assume you can't get NG?
    Solve the problem and save loads of cash??
  13. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    In that case No you cannot have LPG
  14. Mike2007
    Mike2007
    10 Feb 2007
    1,331
    Thanks Received:
    34
    Cumbria
    Country:
    Unless you have a hob and oven for cooking in your basement, change your CH to oil. Run your cooking off your LPG, or maybe I missed something...seems simple
  15. sturharv
    sturharv
    4 Sep 2007
    219
    Thanks Received:
    Lancashire
    Country:
    There is a kitchen on that lower floor level which currently runs off LPG.
    Is LPG much more expensive than oil, I have heard that it is comparible :LOL:
  16. doitall
    doitall
    8 Jan 2005
    19,003
    Thanks Received:
    1,538
    Bath
    Country:
    If the appliances have auto ignition they would be classed as "At risk"
    Oil is considerable cheaper than LPG, but how long that lasts remains to be seen
  17. Mike2007
    Mike2007
    10 Feb 2007
    1,331
    Thanks Received:
    34
    Cumbria
    Country:
    Copy and pasted courteously of an oilman post;
    Cost of Delivered Energy as at November 05
    Electricity
    3.9 to 7.6p/kwh
    Heating Oil (in condensing boiler)
    4.2p/kWh
    LPG (in condensing boiler)
    4.7p/kWh
    Coal (anthracite grains)
    3p/kWh
    Natural Gas
    2.8p/kWh
    Logs in Stove
    0 to 5.1p/kWh
    Wood Chip
    1.5 to 2.1p/kWh
    Pellet
    3.0p/kWh to 3.5p/kWh
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
