LPG boiler in basements?
  • Thread starter Thread starter sturharv
  • Start date Start date
S
sturharv
Just a general question, I know there are regs on installing LPG boilers in basements, basically it isn’t allowed.
What about installing an LPG boiler in a plant room where only two of the outside walls on that floor are below ground, but the other side of the building is at ground level??
There are no outside walls available to the plant room, there would have to be a vertical flue on the boiler.
LPG appliances are not allowed in basements because LPG is heavier than air . Any leaking gas could gather at low level with potentially disastrous consequences.
The big question is:-
Is there a doorway from that room that leads to the outside at low level [plant room floor level]?
I was getting round to that SBDC, if there was a door it would be an lower ground floor.
Sorry I have been a while to reply.
Basically there is an existing plant room, however the building is being extended and 'built onto' the plant room walls. Originally there was a door on the plant room to outside.
Therefore the plant room now has no outside wall available.
The front elevation on that floor (the floor which has the plant rom) is at ground level i.e. you could walk out of the doors at the front to outside, but the rear elevation is built into the land, you would have to go to the floor above to walk out of the rear of the building. The plant room is on the rear elevation, but there is a doorway from that floor (but not the plant room) that leads to the outside at low level.
Hope I have explained it correctly.
:lol:
If your on LPG and not natural gas change over to oil, I assume you can't get NG?
Solve the problem and save loads of cash??
Unless you have a hob and oven for cooking in your basement, change your CH to oil. Run your cooking off your LPG, or maybe I missed something...seems simple
There is a kitchen on that lower floor level which currently runs off LPG.
Is LPG much more expensive than oil, I have heard that it is comparible :lol:
If the appliances have auto ignition they would be classed as "At risk"
Oil is considerable cheaper than LPG, but how long that lasts remains to be seen
Copy and pasted courteously of an oilman post;
Cost of Delivered Energy as at November 05
Electricity
3.9 to 7.6p/kwh
Heating Oil (in condensing boiler)
4.2p/kWh
LPG (in condensing boiler)
4.7p/kWh
Coal (anthracite grains)
3p/kWh
Natural Gas
2.8p/kWh
Logs in Stove
0 to 5.1p/kWh
Wood Chip
1.5 to 2.1p/kWh
Pellet
3.0p/kWh to 3.5p/kWh
