Hello,
I have a 400l unvented cylinder to go in my cellar. But there seems to be conflict between plumbers/advise.
I have had 2 quotes to fit, and decided to position the cylinder myself. Both agreed this would be best as its a real headache.
However.
Plumber A said.
The discharge has to go outside, in a suitably sized pipe. (10 meters long under living room) with 200mm fall over that distance. As far as I know the regs state continuous fall, which I suppose can be achieved but not easily. It is also a little unsightly and there is no suitable drain outside for it to go into. This would mean more cost afterwards to add something.
Plumber B said the fall isn't great enough/too much hassle and it can vented to a space in the cellar (rubble/soil) under another room. So long as an audible alarm is fitted. 25m^2.
Plumber B's option doesn't seem "correct" but obviously is quote is more favorable, and he seemed the most confident/educated.
I called building control and they didn't really have an answer, and said it depends on what the inspector agrees on.
Plumber B was the guy in the brand new van, plumber A the guy in the 15year old transit.
I spoke to building control and they said as per manufacturers instructions, which obviously don't mention either method.
Regards
Ricky
However.
Plumber A said.
Regards
Ricky
