- Joined
- 30 Nov 2023
- Messages
- 7
- Reaction score
- 2
- Country
So we switched from a vented HW tank to an unvented one about 4 months ago (rads were already on an unvented loop) for pressure and volume reasons. Ever since it's been installed we've had a loud humming noise/vibration in the airing cupboard whenever the hot water is on. We've had the installer back out who has drained down the system and done whatever he's done and it's would be fine for a week or two then back to the vibration.
The vibrations occur on the HW feed in/out around the tank but don't impact the CW feed into the tank or that pipework.
I thought it might be a trapped air bubble and I've got air vents both at both input and output from the tank so I've checked these and while there was a little air the noise is still going after they've been bled.
Looking on the forum today I saw mention that it might be a tap so I've just checked and if I run the bath tap in either the main bath or en suite then the noise goes away. This does not happen with any other hot tap. As soon as I turn the tap on the noise comes back which, at least, is progress in the investigation. Both of these taps are the standard basin mixer style tap. There are no other issues with the system i.e. no additional noise when running taps or showers or any leaks.
Any thoughts on next steps?
