Over the course of the week I changed my mind from fitting a heat only boiler and making minimal changes to getting an unvented cylinder fitted with a system boiler adjacent to it. Even with all the plumbing changes this is not significantly more work.
I've measured the water pressure and flow this morning and last night. The lowest reading was this morning at 3.7bar dropping to 0.9 with three mains taps running. With the three taps I got a total flow of 32l/min. Peak pressure was over 4 bar dropping to 1 bar when drawing 34l/min.
Unfortunately whilst the main to the house is new(ish), it's in 20mm MDPE and so I'm losing a lot of pressure along the 15m from the road. Increasing the size is not an option. Why anyone would fit a new 20mm pipe is beyond me!
Based on these results it looks as if an unvented cylinder will work. My question is whether there is typically a noticeable drop in pressure during the summer when water usage is (probably) higher?
Are there any makes of cylinder that I should avoid?
