- Joined
- 31 Mar 2013
- Messages
- 508
- Reaction score
- 48
- Country
You can't drop that statement without some supporting link to the source?
Well I did.
I've not seen the internal construction of the cylinder to make this a 'factual' statement but I work in a field that deals with explosions.Having watched the YouTube video at 0.25 speed on my 4K laptop screen, I seem to see something different to you.
Let's assume that the top and bottom of the cylinder are "attached" to the cylinder using similar construction methods, ie, it is a tube with a top and bottom fitted, and let us also assume that the lids and base are the weakest points. Why would the bottom fail before the top? If the top failed, it would be a copper lid (alone) that hits the ceiling above (and lots of water spraying up and, invariably outwards).
Sorry, I don't understand why the underside- exclusively, will fail and not the top or sides.
I am willing to suggest that the video is not (possibly) completely truthful.
What I don't think has been asked, or the OP has said - is what exactly is the problem being experienced with their vented pumped system that leads them to believe they'd be better off with mains fed unvented?
I didn't say it couldn't happen, what I said was, that is is unlikely to happen without intervention of safety devices, hence the UV cylinder isn't inherently dangerous, much like a gas boiler, but tamper with it and it may well become unsafe, with consequences.
wouldn't happen in a domestic setting
I have to say that I am not that happy and think I made a huge mistake - It would have saved space and been cheaper and pressure would have been better and would have been more fancy. The pump is also noisy when it operates
Never actually seen how one is made but it may be the same process of how other cylinders are made whereby a blank is pressed out of steel so it only has one open end, the coil etc is then installed and then base is welded on, therefore that's the weak point?Sorry, I don't understand why the underside- exclusively, will fail and not the top or sides.
Sorry but you did, hence my response. If you hadn't, I wouldn't have said anything
There's more than just the safety devices being capped there.....wouldn't happen in a domestic setting, as you'd have to bypass all cylinder safety and also have a boiler which heats water past boiling point, which they don't.
Hahah ... yeah right ... apologise .... as if ... get the context right.No need to apologise, but I didn't, hence me quoting the entirety of what I said, not just your selected reading ability. Also, no need to lie and edit posts is there, come on.
If you have an adequate min dynamic mains pressure and flow (As per @Johntheo5 suggests) and a suitable location to allow a 22mm mains supply to be run to it then an easy path/access to run the D2 safety discharge pipework to a suitable internal drain or external space, then yes and unvented could be considered.Is it worth removing a new coffin tank, hot water vented cylinder and pump and installing an unvented ? That was my question in summary
Thanks - Just a final piece of infoHahah ... yeah right ... apologise .... as if ... get the context right.
Jeesh ... grammer lessons on a DIY forum, whatever next.
Unfortunately the statement was that "it wouldn't happen" it doesn't matter follows it. By using the contraction 'wouldn't' meaning 'would not' it means that - a certain thing will not happen - i.e. there is 0/none/nada % chance that it will happen regardless of what text follows it, hence why that was the only quoted part of the comment, the rest of it doesn't matter. That there is 0% chance though is quite simply not the case. There is a chance, however small/unlikely, that the safety devices on an unvented could fail at the same time either be innocent or malicious interference and there is a run away heat source. Not being very specific on a DIY forum can be fraught with risk as there are people that will believe anything and act incorrectly on the back of it.
Edit posts ???? I don't think so , I didn't change any wording, I only quoted the section relative to the comment, happens all the time in here.
Anyways ..... Apologies @JackK for the digression
Again, depends on the mains and the shower - If you have a mains delivering 20L/min @ 3 bar dynamic then yes it will be as good as. Don't forget though there are very few shower that will deliver that amount of flow and if it did then you'd probably drown yourself or strip the skin off your backWould an unvented cylinder perform equal or better to a 3.0 bar pump shower
What I am thinking is to remove the coffin tank and use the discharge pipe that the coffin tank had in the loft to the outisde of the property as the potential location of the vented cylinder - It has 22mm coming into the coffin tank, the discharge is via the overflor pipe in the loft and so all I need is flow and return to the loft and I am doneHahah ... yeah right ... apologise .... as if ... get the context right.
