Hi
I have recently had an unvented direct cylinder fitted by a g3 qualified person - however there seems to be an issue that is hard to get to the bottom of.
when the lower immersion is on for about 1 hour - the discharge pipe starts to drip cold/cool water.
the installer identified this as the pressure reducing valve, and tested the expansion vessel which was factory set at 3.7 bar.
The mains pressure into the property is 2.5 bar - and the suggestion was to get the expansion vessel set at 2.5 bar also to see if this works.
the dripping only seems to be evident when the main immersion is on for an hour or so
This seems to be a trouble shooting issue , with back pressure , check valves , balanced pressures and NRVs all being mentioned as potential resolutions.
Does anyone have any similar issues as above and any ideas what can be done to resolve?
the discharge isn’t a lot - just a fairly constant drip.
Any constructive info or suggestions I can pass on to the installer would be greatly received for my own piece of mind.
best regards
best regards
