up on the roof
25 Sep 2006
London
I will try and be as clear as possible, please bear in mind that i have no idea what i'm talking about.... :?
I work for a church in east london and i was up on the roof the other day, clearing a few leaves etc and noticed that some small patches of the thick, grey roof material are wearing away a little around a skylight.
Underneath there appears to be some sort of tape, a bit like joint tape. I am worried that when it rains, this might become a problem.
Is there anything i can paint over this tape to make it waterproof or anything else i can do?
Many thanks for all your help.
sounds like the lead flashing has worn away :shock: exposing the underlay....or Zak Dingle has been @ it ..you need an ecclesiastical leadworker :wink:
i am praying that i dont need a roofer :wink:
++++++++ the following parts moved in by Rupert ++++++++
deano34 said:
Hello, i asked a question the other day about the roof at the church where i work.
I have taken a few photos, so maybe you can take a look. Is there any way i can patch this problem up?
many thanks again
http://img180.imageshack.us/my.php?image=photo0067001fn4.jpg
http://img273.imageshack.us/my.php?image=photo0065000cu7.jpg
http://img466.imageshack.us/my.php?image=photo0066002mo1.jpg
I have moved this info to your original thread,
No need to have two with the info spread between them.
Mod Rupert
masona said:
See this or this
You have a mesh netting underneath and coated with bitumen/ruberoil type, There're plenty roof repairs materials to chose from many diy superstore
That`s something like Decadex...or similar.......Masona`s dead right about the repair :wink: .......not like the sort of church roof I`m "familiar" with
it looks like a repair to an asphalt roof, the tape is called scrim and is used with a waterproof resin as reinforcement.you might get away with applying another coat of resin, best purchased from a good roofing supplier,5lt tin should do it just brush on like thick paint,ask for aquapol or aquasheild
