Thanks for the replies.
The structural engineer hasn't been brilliant with our enquiries so far. The notes on the floor joists only say 195 X 47 c24 grade timbers bolted with M10 bolts @ 600 centres. I was unsure if this meant the spacing between the joists or the distance of the bolts. Guessing it's bolts as 400 centres is what were going for between the joists as it's a 4m span.
Thanks again Woody, just the Info that I needed. With coach bolts having the inbuilt washer and square section do they need washers on the back aswell?, guessing not.
With regards to padstones, (which haven't been made clear by the SE either) if the inner wall above the piers and initial UB is built with 3.5n blocks I'm assuming it's a pretty wide padstone that will be needed. Would this go across both skins at new roof (soffit) height or just the inner course?
Got the builders round this weekend but don't want to sound completely clueless.
Thanks again.
Thanks again.
