Hi there, hope you can help.
I have one of those Ikea wires lighting systems in the kitchen (think it is the Termosfar one originally) and have already replaced the transformer once. My fault as I didn't realise the limits on the bulb wattage size and overloaded it.
As there is a problem with the replacement transformer - scavanged from a different Ikea lighting set and probably not entirely compatible - I am considering replacing this with one which I can use with a dimmer switch.
What do I need to look for? Both in terms of the transformer and the dimmer switch? There are currently 3 x 20w lamps on the wire system. If I can get a transformer which can cope with dimming I will want to add one, poss two more 20w lamps.
Thanks in advance for any assistance.
Regards,
Lori
Regards,
Lori
