Based in the UK. Changed from a Potterton controller to a hive mini for my heating and hot water system.
But coming across an issue……
As you’ll see from the pictures of the rear of the old controller and the controller diagram it have two cables in L, two in N. A yellow in 3 and a red in 4. There was a loop from L into 5.
When I’ve changed them out into the hive I’ve put the two L into L. The two N into N. The yellow into 1. The red into 2. I’ve got rid of the loop. If I turn the heating or hot water on they operate and the white sting valves turn on (amber light) and the spring valves open. BUT when I turn the heating or hot water the boiler still runs?
Any suggestions? Thanks in advance
