Hi guys,
The current radiators in my house are old single panel ones all of them measuring approximately 150cm x 70cm.
According to the chart on the following page this rad should have an output of less than 1450 watts:
http://www.simplifydiy.com/plumbing-and-heating/radiators/power
I have used many of the online BTU calculators, I took the highest reading (the calculator took into account glazing size, type, type or room or floor above and below, number of external walls, type of external walls etc) and added 20% to be safe, that gave me a required output of 843 watts. As you can see that is a lot less than the current radiator if the chart is to be believed. The radiator gets hot but the room is still cold so I need a bigger radiator.
What do you guys recon, is the chart no good or is it the online calculators?
