I have an oil fired flow and return vented system with 17 rads. All the downstairs are fine and get hot but upstairs only one gets reasonably hot two more are barely lukewarm and the other three are stone cold although on one of them there is hot water below the inlet valve but it is cold at the lockshield end. I have had two plumbers confront the problem and between them they have powerflushed three times fitted two vents one near the header tank and one under the flloor at the highest point on the flow pipe, added inhibiter and fitted a new pump. One bypassed the thermostat on the boiler and the water was so hot all the rads worked. That was in the summer but the system has now reverted to its old ways. I have since backflushed, bled and made a reasonable attempt at balancing the system. All the rads fill with water normally and all the valves are working. I have run out of ideas and money. Can anyone help please?
