Hey all,
Looking for a bit of advice on fitting a new UPVC back door on a typical mid terrace house, done quite a lot of timber casings and doors over the years but never UPVC.
The old timber casing that has to come out must have been made out of ex 4" timber and has been finished at 97mm wide (inside face) by 70mm deep approx, the new UPVC casing will be approx 70mm x 70mm, obviously this will mean there will be a gap as it's smaller.
The old timber casing is pushed up to the back face of the outside brickwork, and ideally I would have done this with the new UPVC unit. However if I did this would mean that there would be and almost 30mm gap on the inside between face of kitchen wall and face of UPVC frame. Can I position and fix the new UPVC unit so it sits in the same place internally as the old casing (flush with the face of kitchen wall). This would effectively give me a gap between outside face of the casing and inside face on the outer skin of about 30mm. I would then cover this gap with some 45mm upvc trim and polysulphide sealant.
Basically I want to know if it's ok to cover this 30mm gap with trim as in the past I have always fitted doors tight to outer skin of brick ans avoided this. It would be easier this way than having to have the 30mm gap on the inside/kitchen side and have to make it good.
I had thought of fitting between brickwork rather than behind and making a lining/architrave inside but they (inlaws lol) want it done this way to leave maximum width with the door.
Sorry for the rambling post.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
