The fuse in the white plug is purely to protect the white plug and anyone poking things in it no other reason.
it can possibly be used safely with a 13 amp fuse but in your case and for what your using it for it only needs a 3 or a 5, the lowest fuse suitable is always the safest option
As said previously the black thing will most likely have a fuse or similar sealed inside the unit
Yes but why bother with a fuse at all when the black adaptor has one why not leave it blank sure it will still power right seen as the black adaptor has a fuse why bother adding too I guess I'm asking because what's the purpose or function is it a necessary action to,need to have a fuse in the white plug as well as the fuse built in the adaptor? Does it help with a short circuit or something maybe alone the black adaptors fuse won't help a short circuit by its self
What do you mean by poking things in the white plug it protects them? How prevent electrical shock?
So is that not double loaded the socket. As the black adaptor has a fuse built in now on top on that we are putting a 13 amp fuse or even lower 5 amp or 3 amp I never knew that you could do that
It's like putting a 13 amp fuse in a plug then using a another 13 amp adaptor similar thing isn't
Oh well I never knew
But just with those plugs I have been using a tooth brush with an shaver plug and charging for years never knew it was unsafe even shaver I use the adaptors hmmm you guys have got me thinking now
And one more thing I noticed us use plugs that are 2 pin square but my tooth brush using a round 2 pin charger which country uses the rounder 2 pn plugs then?
And also how do you guys know oh a 3 amp fuse will. Be fine with that adaptor if I was to use it not that I will or 13 amp would of been fine
Because I'm using a charger that's got 2 pin but I put in into a plug that's a shaver type adaptor but now I'm not even sure how to tell if even the fuse in there is fine
