Used 12mm bolts but hole in TV bracked is only 10mm!!!
30 Mar 2010
Rhondda Cynon Taff
Yes should have measured first. Bad mistake....
What are my chances of success trying to make hole in the metal bigger?
Step drill bit or reamer?
Or give up, fill in the hole I've made and try again with smaller bolts?
You should be able to put a drill of suitable size through the holes easily enough.
12mm for a tv.
forget the hole you drilled and buy appropriate fixings.
Trouble is it fell off the wall once, then I tried those gripit fittings. Load of crap..... Just pulled out the plasterboard.
Yeh 12mm probably overkill but I wanted to make sure this time. Drilled into the brick etc. The bolts are in pretty solid now.
Trouble is the holes are there, bolts are in now - in hindsight of course, 10mm would be better.
talk about going round the houses.
what a load of bodgers.
