K
kai
Here's a method I used, when my hot water cylinder needed replacement.
From the two 13amp fuse-connection units, I fed two industrial type splashpoof 16amp sockets, one for the Nightime Element, and one for the Booster element.
When the plumber came to replace the cylinder, all I needed to do was hand to him two lengths of heat resistant flex, so he could connect to the elements, and he could just plug them into the sockets.
Testing the Nightime economy seven element was easy, as the plug was placed into the Boost supply and switched on to test the element, before being plugged back into the proper socket - Labelled of Course.
[/img]
