Using 300mm diamond disc
7 Dec 2006
Cheshire
Not sure if this should be in tools and materials. I've got a few openings to cut in cavity walls, but not able to get a clean cut right through imperial sized bricks, do the makes of machine vary in depth of cut, i'm using a petrol powered Makita one the guard prevents me cutting about the last 8mm of brick.
Most people drill a series of holes through the wall as a guide and then cut from both sides, then simply knock the bricks with a lump hammer to break through.
nearly all of them are like that, you'll get 95% through a 4inch wall but not quite all the way.
