Hi there,
I have 2 questions, which I hope you can answer:
1. If I cut the 15mm copper pipe feeding my kitchen tap using an automatic pipe / tube cutter (Screwfix 36198), will it leave sharp metal burrs at the cut edge that would need filing off?
2. Does the pipe cutter slide onto the pipe easily by stretching it open, or can it only be used on pipes before they are joined together, if I've described that correctly?
Thank you for your advice.
Mutley56
Mutley56
