Using filler over aluminium foil tape
8 Sep 2010
South West Wales
Hi
I have recently insulated and plasterboarded a ceiling . I put silver aluminium foil tape around the perimeter of the insulation. I now want to fill the gaps between the plasterboard ceiling and walls. There is aluminium foil within this gaps, both at the back and a little on the wall. Is it ok to use filler directly in here or will the aluminium foil need primer (or something) to help the filler adhere?
If it makes any difference I've got Toupret filler. After filling I was planning to finish with caulk before decroating.
Many thanks
How big is gap?
Small gaps I use stixall polymer
Bigger gaps can be filled but if board has paper edges then fine. Dry dusty cut edge needs sealing so filler sticks.
Then put a tape over before you skim.
I've also used foam, cut flat and tape over
How big is gap?
The gaps vary around the perimeter. At the widest points it's 10mm.
Good plan. I wasn't going to bother filling the smaller gaps. I was just going to fill the larger spaces so that it isn't all filled with caulk/sealant. Stixall polymer, I think that might be similar to Geocel The Works, which I already have some of. Would you say that's better to use than caulk?
Good thinking - I hadn't thought of that. The PB edges are all cut, so I'll look to seal them first then. Any suggestions as to what to use to seal the edges?
I won't be skimming. I'm planning to paint the plasterboard as is, after going around the perimeter edges and filling screw heads. I'll prime/seal the plasterboard before applying the final paint.
Many thanks
Seal gap with waterproof PVA. Small wood glue 50/50 with water or gardz. Then use the filler you have and when set after 45 mins or so, tape with fine mesh or fibre fuse then more filler.
