Hi
I have recently insulated and plasterboarded a ceiling . I put silver aluminium foil tape around the perimeter of the insulation. I now want to fill the gaps between the plasterboard ceiling and walls. There is aluminium foil within this gaps, both at the back and a little on the wall. Is it ok to use filler directly in here or will the aluminium foil need primer (or something) to help the filler adhere?
If it makes any difference I've got Toupret filler. After filling I was planning to finish with caulk before decroating.
Many thanks
Many thanks
